The pocket rocket
Where did you get the rad from buddy?
Nice purchases :thumbs:
Adam_sx
Post by Adam_sx »
Got the rad from cgb motorsport as they had one in stock and a few other bits i needed
Normally try to my best to use mike @ gt-turbo-spares but he just didn't have the bits i needed this time round
Adam_sx
Post by Adam_sx »
Update ....... Its broken again :D
This time i've cracked a liner.... Pictures will come up soon once ive found my lead
I admire your ability to continue smiling :D
Adam_sx
Post by Adam_sx »
Been busy ordering new parts tonight, new liners, pistons, conrods, timing chain, tensioner. The rest of the gaskets n seals will be ordered from renault as the non gen stuff just dont last
Pro mod head is on order should be a 10day turn round, flowed, 3 angle valve seats etc etc
Should have the crank n block sent away for a regrind this saturday and order a piper 285 cam kit n vernier through the machine shop
Shit news about the liner, but thats the way to handle a set back. Rebuild it better and stronger. Top effort, well done and hope to see you and the car at the dyno day:thumbs:
What a bugger! I hope you get it sorted soon, Its such a great looking little car.
That's the TNT syndrome in effect!
Good on you sticking with it, be worth it in the long run when you see everyone crowded round it at the next big meeting :)
Adam_sx
Post by Adam_sx »
Only a couple of pictures not really showing much and shocking quality
Spent all evening cleaning the block best as i could, chasing every thread on the block and crank and helicoiling sump threads as 2 had stripped causing a leak and 2 are just falling apart so gunna fix them once ive got another helicoil kit
Also checked the v5 vs the engine block number.... shock it doesn't have its original block in there
Shocking pictures and they don't show much!! ;)
Amazed that is a non-original engine! About time you slapped a V8 in there :nod:
