Toyota Supra "Raijin"
haha yes John cutting the grass indeed mate
and it's a shame you didn't still have that active spoiler assembly, people go totally nuts for them.
ok so updates today, finally pieced together the entire active spoiler assembly and fitted it to the car, here are some photos;
Lights out
Old pan removed
Grille removed
Active spoiler fitted and trialing a tilted plate bracket
Volia
All i have to do in the morning is paint behind the grille so there's no manky bits and bobs
plus fit the manual ecu clever box thing so i can control the spoiler manually whenever i want.
Lights out
Old pan removed
Grille removed
Volia
Nice work Dan! Paint the grille black though
Like the signature video.......you look like you're running mad negative camber; is that a trick of the eye or have you started using ONI spec settings
Stuart wrote:Nice work Dan! Paint the grille black though
Cheers Stu
As for the video, the car does natually have lovely rear camber. But the gopro made it look alot more severe that it actually is
ooof, it's getting there
