The pocket rocket
Adam_sx
The pocket rocket
Post by Adam_sx »
So i took a gamble and brought the car off my cousin as a non runner, no mot or tax, water mixing with oil project
Spec is pretty much unknown but have found a few things:
Alloy header tank
ktec alloy carb top
mocal oil cooler
alloy degassing camber
ktec bored out turbo elbow
bigger alloy intercooler
samco silicone hoses everywhere
engine rebuilt back in 2006 new pistons+liners, bottom end rebuild
scorpion straight through exhaust system
clifford g5 alarm
Ecotek valve (removed as soon as i saw it)
This is how the car turned up on my door step after being towed,
Carb and turbo had both been removed and put in the footwell :)
then i started work on the engine to get the liner seals changed and inspect the rest for damage
Whilst waiting for parts to turn up from renault i decided to take the front bumper, front archs and side skirts.
Found a few medium size rusted through sections in the drivers outer sill and a small hole in the passenger side outer sill.
So far have cut out the rusted sections and put in new metal and welded it, seam sealed and painted with paint, got to do the rear of the drivers sill as the inner sill needs a bit of welding but need to drop the tank as its too close for my liking
Replaced both front wheel bearings and bottom ball joints as they were knackered
Then my bits from renault turned up :)
new heatshields as mine are missing
new headgasket kit
new rear window square trims as mine are falling apart
new sideskirt clips as most of mine have broke
Metre of brake servo hose as some knob has fitted a ecotek valve in mine
New coolant
Sump painted black by my brother
Adam_sx
Post by Adam_sx »
Also found out the whole car has dynamat everywhere
Rebuilt the carb
Dinner trays are good for carb rebuilds :mrgreen: found out some muppet had got the accel pump spring wrong way around so it was sitting on the diaphram and would of split it sooner or later
Then i got the engine all back together after cleaning the liner platforms (Drill wire brush attachment and flat screwdriver works wonders) new liner seals fitted, new headgasket
After much internet searching i found out where each samco hose should be
Engine bay now its fully functional but slightly smokey from turbo oil seal
Turned him around so i can start work on the back end so took pics of the front end all rust treated and painted black
Bolted the front bumper and pushed the broken grill back in place to look better for the moment
Now i got to fix up the back end
drop fuel tank
do small bit of welding on sills
fix the fuel pump and filter on properly
fix a fuel pipe leak
make a new reserve tank strap
raise back end as currently sitting far too low
Got to sort out the interior aswell as its a bit of a mess :roll:
Then hopefully get it to work for a mot and i just need to get the turbo rebuilt and the car onto the rolling road for a fueling check and boost increase
Adam_sx
Post by Adam_sx »
did a bit of filler and prep work where i had to weld in a new bit of metal on the top of the sill the other day during the week
all primered ready for a rub down and lick of paint :nodyes:
And had a decent amount of progress today :)
Sill has been painted
Drivers and passenger rear sections of sill holes has been fixed and strengthened so much its a new jacking point :D
Then the front archs, sills, floor pan, boot floor pan basically everywhere under the car has been waxoyl'd super thick :mrgreen:
My reserve tank strap had rusted away and snapped and i wasnt going to pay
Adam_sx
Post by Adam_sx »
started working again now the snows over
Before
My little helper making sure i dont grind my fingers again
And After
Doesn't look like much but we've done a fair bit.
Removed the tailgate as its scrap but kept all the wiring safe.
Removed the rear seats, drivers seat, boot carpet and under back seat carpet.
Removed the show roll cage.
Fixed the rust hole on the rear bumper mount and fuel filler neck mounting.
Fixed the captive nut so the bolt that holds the drivers seat frame to the body so it actaully screws into something and the seat dont flap about . :lol:
Hammered off all the renault sound deadening from the boot floor and rear arch sides. :muahaha:
But i got pokey screwdriver happy and found another 2 rust holes
So i've crossed a few things of my to do list but added a few aswell doh! :)
The worst rusty hole less than 1 inch away from the rear seat belt mounting point :D
Some of the weld went shit near to the end as i ran out of gas and the gas regulator packed up :x
This is just the inside part of the panel i've fixed, got to do the part in the wheel arch tonight :)
Oh and you can see where i removed some of the sound deadening on the arch and floor
Rear seat backs repainted black
Interior going back in
Shopping this morning got some new engine bits
Took the rear windows out to change the 3 little rubber bits and well i'll let the pictures do the talking.......
My newly paint floor is going to get ruined :( even tho it'll be recovered in sound deadening anyways
Looks like the welder is coming out again..... surely there cannot be anymore rust after this?
Adam_sx
Post by Adam_sx »
progress so far this weekend
Then started to fix all the messed up wiring loom and poor clifford g5 installation that was hanging down everywhere, so out came the dash and started re-tapeing the whole thing back into shape.
Removed all the scotch lock's and crap solder joints and replaced with heatshrink crimp connectors 8)
Adam_sx
Post by Adam_sx »
small update :)
Bolted a new battery tray in.
Put a spare battery on and checked all the electrics work everything seems good 8)
And it the engine still starts :D
Little video of it alive again albeit slightly smokey and idle a tad high
http://www.youtube.com/watch?v=oD_h_FQaw3I
Going to have to flush the oil as its gone a tad milky from where i couldn't drain the oil cooler so suspect it was full of water :roll:
Fitted new side skirt clips on the car and put the skirts and front arches back on and it looks like a 5 turbo again :D
MOT some time next month just need to sort the little things out first
Adam_sx
Post by Adam_sx »
ok the brakes wont bleed properly :roll: so i went out and brought a new master cylinder as it only cost
Adam_sx
Post by Adam_sx »
Well my brother has today and tomorrow off work for his birthday
so i was expecting him to play on his pc all day or something but..... instead he has gone and done a shit load of bodywork preping for me :mrgreen:
He shall be rewarded by supplying him curry form the local takeaway :)
Love it to bits!
That'll be brilliant when it's finished.
Adam_sx
Post by Adam_sx »
And that is all so far :)
Just ordered 4 toyo t1r's for the wheels
Hopefully get it out at weekends and on track around april time after the full respray has been done
