Grace. SOLD
I remember you saying that you did yours a while ago. Did you buy the bits from Eurocarparts or something? They will need doing, so I guess that may as well go on the shopping list.
mikeb
Post by mikeb »
Yes stu got all my parts from GSF dirt cheap if you won,t get all the parts together you won,t to change or repair come down to the factory over the holiday.
May be get a couple of us together and hit it hard.
Could also get rob over to do the stereo etc
mike
life rules
That may be a good idea mate :) My time off is a bit limited (didn't book any :( )
How's the weather down your part? Trev tells me he has had loads of snow?
mikeb
Post by mikeb »
Yep it,s very white hear dropped about three or four inches in a couple of hours yesterday
Love it make,s everything look clean and peacefull.
mike
life rules
stacks of snow in coldchester :)
good to hear you have heat now :thumbs:
So one question
If my valves were closed for the 9 months that I've owned the car, what effect would this have had on the cooling of the engine? Are there any repercussions from this?
IWANT1
Post by IWANT1 »
None really, you should now be able to bring temps down a bit more on a summer track day as in theory the effect of having the cabin blower going on hot would very slightly low the water temps whilst roasting you in the cabin.
Summer temperature reductions I can see but I still don't understand these Valves. If they were closed, and therefore not allowing hot air in, was the water circulating through the matrix? If not, surely the water wasn't making a full circuit at all, so why didn't the car overheat?
IWANT1
Post by IWANT1 »
<meta http-equiv="Content-Type" content="text/html; charset=utf-8"><meta name="ProgId" content="Word.Document"><meta name="Generator" content="Microsoft Word 11"><meta name="Originator" content="Microsoft Word 11"><link rel="File-List" href="file:///C:%5CDOCUME%7E1%5CLEE%7E1.FOR%5CLOCALS%7E1%5CTemp%5Cmsohtml1%5C01%5Cclip_filelist.xml"><!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <w:DontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><style> <!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:612.0pt 792.0pt; margin:72.0pt 90.0pt 72.0pt 90.0pt; mso-header-margin:35.4pt; mso-footer-margin:35.4pt; mso-paper-source:0;} div.Section1 {page:Section1;} --> </style><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Been a while since i saw a vw engine bay but iam guessing the valves your talking about are in the two pipes to and from the heater matrix, these just tap into the hot water in the block if both pipes were bunged it makes no difference they are not part of the primary cooling system.
As to the water pump - when I had the cambelt changed on Kirsty's MKIV Gti we changed the water pump - lucky we did as it had effectively disintegrated .. i.e. only a third of the impellor existed .. so it worked but probably wasn't too effective.
