the landie has had full respray in green (ex police so was white)
<o></o>protection and performance cage
<o></o>16x10 d44 modular rims with new 35x12.5 maxxis creepy crawler tyres
<o></o>has all new brakes fitted drums shoes calipers pads and drilled and grooved discs, new lines and goodridge +2 inch braided hoses
<o></o>has +2 inch bearmach off road springs fitted with pro comp es9000 +2 inch travel shocks fitted on -2 inch drop mounts
<o></o>has + 2 inch lifting blocks under springs giving it a total of +4 inch lift
<o></o>terrafirma rear spring retaininghooks / dislocation cones
rebel 4x4 galv steering guard
front diff guard
brand new jackable sills/ tree sliders
+2 inch extended flexi archs
<o></o>tmaxx 12500 winch fitted in custom rear cross member (requires wiring up)
<o></o>brand new series doors with rocky mountain alloy tops
<o></o>turbo boost and volt gauges
exhaust exits neatly throgh n/s quarter panel to avoid damage from rocks
<o></o>1 off snorkel
<o></o>subaru impreza sti seats in front (very comfy)
<o></o>gay subaru impreza scoop in bonnet
<o></o>twin batteries
<o></o>heavy duty alternator
<o></o>heavy duty clutch and fork fitted
<o></o>new clutch slave and master cylinders
<o></o>5x hella rallye 3000 spot lamps (cost a fortune)
<o></o>2x britax blue spots on grille (one cracked lens)
<o></o>tree brush guards fitted between wings and roof
<o></o>new windscreen
<o></o>new lights all round
<o></o>td5 lamp surrounds
<o></o>2x recovery points on rebel guard 2x on front of cage and 2x on rear cross member
<o></o>Terrafirma winch bumper, winch coming tue
<o></o>rear light guards fitted
<o></o>5 spots on rear
<o></o>silicon turbo hoses
<o>
Sadly not much snow up here TK plenty down your way?<o></o></o>
<o> </o>
nice spec mate ,what diesel engine has it got ? " go anywhere but will carry f**k all " lol .what have you in mind sedate greenlaning or devils pit to scare the crap out of yourself .
Its a proper Defender so has a 200tdi not some old disco engine shoved in.
Bit of greenlaining first to iron out any teeting problems the off to ThreeHoles over xmas for a start then of to Devils pit or similer if all goes well.
Cheers for the comments guys, its definitly a bit of an animal
Anyone got any rad fans kicking about looking at taking of the viscouse fan?
lee
