The R32 GTR has the MAF free PFC on it. First map session since engine done worked on full throttle stuff etc and thats fine, as is general running/driving (I did have a base map to start with tbh) but now getting big probs with part throttle and not getting much help from the people I would have thought would know.
Basically if you run the car through the revs on part throttle, or for example hold it steady throttle as you would through a corner on track, it richens right up to a flat 10 on the AFR then fluffs up. I haven't really tried yet to rectify it but have been told "thats a d jetro, they're shit cos they all do that and there's nothing you can do to stop it". which a, I didn't think was much help, and B, not sure i believe,
I'm yet to go into the PFC forums etc but have also heard there are settings in there which may sort it.
The car will be purely for track use and traillered once it's all sorted so i'm not looking for a map that will commute me to into the city for work but the way it is on the road will not work on track at mo.
Again, maybe stoopid questions but i'm a bit new to all this so as well as dig the forums I thought it worth an ask....?
before I move on to the second question, which is: Is it possible to get HKS 2540s to give full boost before 5200rpm on an rb26, and if so what do I do cos I haven't experienced that kind of lag since Gran Turismo 1 came out and I put the biggest possible turbo on the car once i had enough money...
