Really cant believe how light this is compared to the stock housing turbos. Lets hope it works aswell as it looks. Taking it to Neil @ Thermal Logic on Sat for some pipeage.
Kid in a sweet shop
Did another job today that ive been putting off for ages. measured up for the oil cooler so i cant do any more with that till ive made up some brackets etc. So i started fitting my Aerocatches.
Didnt get these complete yet as i had to go out. But the bulk of the dicking around is done. These wont be 100% installed as i want to have the bonnet painted once im finished so will bond them in for a final finish once its been painted.
The under skin requires finishing but the top skin is done and the strike pins are in.
Naturally i took some pics along the way
Little tool i made to make this job a shtload easier.
Haha, simple but effextive mate. I made a pair of them to substitute the Aerocatch strike pins. You just set them up and lean gently on the bonnet.
They leave you with 2 perfect dimples to drill.
Makes fitting a piece of piss and takes the guess work out.
Easy eh :-)
Knocked up a little bracket for the cooler today. This will be welded to the underside of my offside inner wing, seam sealed and painted. Cut some rubber tabs to dampen it too.
Sorry for cak phone pics.
