jaffa
ordered loads of bits today from euro car parts for collection tomorrow like cambelt/ gaskets/ waterpump service bits etc..
rollcage turned up today and sitting in the garage this will be repainted orange :D
i have front and rear large neuspeed anti rollbars to fit and lower front brace, them combined with poly bushes throughout and avo coilovers it should be pretty sorted on the handling side of things
also the final decision has been made and jaffa will be a berg cup arched mk1 :D :D
jamies a bad influence
Berg Cup? :D Glad you're blaming Jamie.
Where on Earth did you source Neuspeed ARB's?
Good going Trev, will have to get my sunglasses ready for when jaffa comes out:coolgleamA:
Well done Trev, sounds awesome!
oow .. can't wait to see it bud.
IWANT1
Post by IWANT1 »
Looking good trev, slightly off topic but still VW what are K03s????
ko3s is a turbo lee , why you ask ?
just back from the unit and progress is slow but the engine is now ready to go in the hole, cambelt,waterpump,alternator,inlet manifold all fitted
gear linkages all fitted
not all has gone to plan today, i had to replace the water inlet pipe to the head that is held in place with 3 hex bolts and yep 2 of them snapped in the head, eventually got them out without the need to drill and tap them so was a big relief.
hopefully i'l be able to do a bit more tomorrow,
IWANT1
Post by IWANT1 »
Tk wrote:ko3s is a turbo lee , why you ask ?
<meta http-equiv="Content-Type" content="text/html; charset=utf-8"><meta name="ProgId" content="Word.Document"><meta name="Generator" content="Microsoft Word 11"><meta name="Originator" content="Microsoft Word 11"><link rel="File-List" href="file:///C:%5CDOCUME%7E1%5CLEE%7E1.FOR%5CLOCALS%7E1%5CTemp%5Cmsohtml1%5C01%5Cclip_filelist.xml"><!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <w:DontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><style> <!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:612.0pt 792.0pt; margin:72.0pt 90.0pt 72.0pt 90.0pt; mso-header-margin:35.4pt; mso-footer-margin:35.4pt; mso-paper-source:0;} div.Section1 {page:Section1;} --> </style><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]-->
Looking at possible replacements for the clio, and seen a few golf
got side tracked with work and stuff today so not much progress
tomorrow i hope to make some
i ordered my new rod ends today for my front arb
rollcage had turned up and i'v managed to paint my garage at home floor orange :)
Mate, that is crap!! At least you could have masked up :)
A great contrast to Fil's project garage eh?
Are you going for the orange flocked dash now too? ;)
