Rover tomcat-updated
Bealo
Post by Bealo »
I can vouch that it goes well on track, had a few good scraps at Snett with Scott.
Good power Scott.
tomcat
Post by tomcat »
Finally got it back together
Have tidied it up a bit under the engine bay
also treated it to new lower suspension arms, outer cv joints and gaiters, new hoses, new harder turbo bolts, ported manifold, new race f series brake pads, new ap disks, another hub, gear knob!
I also rebuilt the gearbox replaced syncros, now have differant 3rd and 4th gears,and re-shimmed -was a bit of a nightmare as it wasn't right first time so I had to do it it again :(
Lightened/balenced flywheel -more because the paddle cluch had worn it badly.
Touch would it seems ok
There's a few quid there then :)
Good to see you back on track Scott. Do you have any more work planned or are you ready to come out to play now?
tomcat
Post by tomcat »
stuart wrote:There's a few quid there then :)
not too bad gearbox I rebuilt using a spare box, discs and pads were the only big cost
yeah going to north weald in may for the drag meet , hopefully a trackday soon in the next month also
car feels much faster after you havent driven them for a couple of months!
tomcat
new look
Post by tomcat »
was time for a change
Like it Scott, black on white always looks super cool!
Very nice, it's got a kind of stealth look to it now:thumbs:
100% better. Really nice that Scott. Well done mate.
tomcat
amd power runs
Post by tomcat »
I thought Id give the tomcat a power run to see if its still making good power before trackday
I was pretty happy with the result car felt strong right through the range, they actually hit the rev limiter on both runs
Figures are down a bit on last figures but might be rr being more accurate.
run 1 was 13-14psi, run 2 at 18psi I could have gone higher on boost but thought it was better to leave it at my normal settings.
