Went to the Classic Ford show yesterday and ran the Mondeo for the first time.
Posted a best and respectable time of 15.2 @ 94 mph with a 2.4 60 ft.
Room for improvement on the launch, its one of the hardest i've run up the strip due to the dual mass flywheel, its not very forgiving.
When its a bit cooler i am aiming for a 14.9, be very happy with that for a 1500kg+ family car.
http://www.youtube.com/watch?v=bLtCZnaRZiQ
Mondeo ST220 at Santa Pod
Ford Mondeo ST220
I know, problem is that would mean upping the pressures afterwards, and i would never run on the road like that, so in a way, its a little bit of a cheat!stuart wrote:I only meant dropping the fronts to 20psi for the runs, that's the extent of my 'mucking around'
Grip isnt a problem though, being able to launch it at the point it wont bog down or spin is also the same point the DMF likes to spring apart and that will reduce its life, so i had to be sympathetic.
I played around with pressures on the Maestro and found it knocked down my terminal speed as it increased rolling resistance. The best 60ft i ever did of 2.2 was done on 30psi for the front, which is what i always used to run on the road.
Ford Mondeo ST220
Bart wrote:good video mate.
were was your car parked then as i walked round the show and didnt see it mate?
the best times ive run in cars is at RS central day in mid april nice dense air:coolgleamA: and also lot less cars there so can get more runs in.
It was in a field somewhere till i ran it, from about 1230pm till 4pm, would of been parked up in the queue.
Here it is.
Ford Mondeo ST220
