Cool, I'll speak to Christian in the morning....might as well get it all done in one go.Gerry H wrote:They're getting the bungs in to do the job so I suggest you contact APT and ask for the same.
Is your ECU standard Gerry?? As far as I know you can just plug in an Evo 5-7 ECU and then you can ECUtek it, if you wanted!!??!!
