Everything is finally fitted and the suspension ride height sorted and settled so I took the car for its geo today.
The ride height is 323 mm front and 305 mm rear (measured arch to centre of the wheel). The front should really be at 320 mm for the perfect track set up but I have a number of speed bumps near my house. Luckily the 323 mm works just fine with just a slight drag on the undertray.
So the car was put onto the Hunter machine
And my body weight added to the driver's seat
These shots give you an idea of the camber the car was running pre adjustment
and here's the pre-adjustment geo
We were quite shocked by how well my garage had set the front toe (after fitting new tie rods) without the use of any equipment! Caster was looking good, front camber was more than expected. I've always read swapping the Evo mounts (left to right and vice versa) gives -2.5 degrees but on my car it was much nearer -3. The imbalance would need to be sorted and I had brought along a couple of camber correction bolts supplied by my local BMW dealer. Very strange these camber bolts. We were expecting lobes on them on which to adjust but they are just smaller than standard diameter bolts. It's also weird just what adjustment CAN be done since the two bottom bolts on the dampers don't really provide any pivot for the camber correction bolt to do its work.
Anyway, we fitted the correction bolt to the left wheel to try to reduce the camber. We found the bolt didn't really do much so I have more camber on the front than I wanted. To balance things up we added an extra quarter of a degree negative camber (to what I originally wanted) to the rear.
The final readout
Took the long way home which took in some pretty bumpy B roads. The dampers are set on 7 (9 is softest, 1 hardest) and the car astounded me. The suspension can feel a little harsh over ridges and bumps and 'jiggly' in general. However, when up to speed it just controls the wheels and body so well. The wheels were permanently in contact with the ground which I don't think would have been the case with the old 328.
Cadwell on Thursday will be the real test.
