the harnesses are currently mounted using eylets from rear belt holes in the floor as they were last year, im thinking of using the cage/harness bar but there seems to be pros and cons ,
the mk1 does run when you put a battery on it , the whole brake system needs bleeding though and coilovers need setting up , apart from that good to go with the gti 8v engine
if i can find time for the ol gal and give her a little love i'd like her to have a trip to cadwell
oh yes there is also no handbrake due to some tit drilling the cable when fitting an eyelet for the harness
i just wish i had a nice unit and time for her i have everything now bar a set of carbs
