I do love these updates, seeing how much work goes into projects like this really makes you appreciate them so much more.
I'm surprised how short the wheelie bars look though
Mustang Update
Stunning work as usual Fil. I also want a go in this beast when done.
That steering joint is mighty close to the headers. You must have some very solid engine mounts/chassis to stop it all moving and locking your steering. I had this problem a few years ago with a V8 in a Capri mk 1.
Good luck with the rest of the build mate.
Be Cool Radiator turned up from the states, little bit of fabricating and got it mounted using the original rad bar
www.ragingbullracing.co.uk
- ScoobieWRX
Industrial size rad for industrial sized power.
It's all so shiny and lovely and looks so gorgeous seems a shame to bolt it all in. That rad would look great on my wall
Twin 12's should keep it cool, hoping to fit the transmission cooler and prop loop today, ratchet shifter should be here early next week which will be the next little project.stuart wrote:What are they? Twin 16's?
I shouldn't be surprised; everything about the build is specced so far beyond the normal high performance stuff, it makes it difficult to retain perspective.
What's next Buddy?
Need to do a couple of bits on the Dodge and clean the GMC over the weekend too but still chipping away
