Ok, this is what the new engine will be and the rough spec.
Cosworth 2.0Ltr 16v YB
200 Block
Full engine rebuild
0.5 mahle pistons with low compression bowls and valve cut outs
New little ends and rod bushes
Genuine WRC head gasket
New main and big end ACL race bearings
Balanced and polished crank shaft
High pressure oil pump
ARP Conrod bolts
Alcon 6 paddle clutch
Cometic gaskets (except for the head gasket)
Ported and polished cylinder head
BD10 Exhaust cam
BD14 inlet cam
Vernier ajustable cam pulleys
Brand new tappets
Siemens 850cc fuel injectors
? Turbo
GRP A Coil
GRP A fuel pump and uprated wiring loom
Samco boost and water hoses
Alloy water swirl pot
Alloy radiator
Alloy intercooler
New cambelt and tensioner
IK31 iridium spark plugs or Platinum
New engine details in full
Ian200sx wrote:who's going to build it? what power is the aim?
its our new sponsor mate
streetracers motorsport centre based in leicester
power to start with is going to be around the 350bhp and then over next winter little more work done to the engine to get around the 450BHP ready for a full season of time attack:sifone:
We'll be using an Emerald ecu.
A wasted spark set up is not something that I have looked into or something that Gordon has mentioned. Different tuners favour different methods. Now that the question has been raised I will mention it to Gordon.
We have known Gordon since we first built our car over 3 years ago and know his work well. We have complete trust in his work..............but i'll still ask the question.
I have done a bit of surfing and can now explain part of why our spec doesn't include a wasted spark setup. If this was a road car then it would be of advantage for the smoothness of running and the hassle free setup. As the main focus of the car is track use and as such things like plugs will be changed frequently a wasted spark setup is not essential.
Thats as far as my knowledge goes:)
Please correct me if i'm wrong.
hassle free is what you want mate,so with wasted spark you dont have moving parts like rotor arm ,cap to break or crack,
that combined with a better spark,nearly all new stuff is wasted spark or coil on plug
these guys built many cosworth motors before??
That's cool, I wasn't criticising your choice as there are many Cossie's out there still running the Grp A Coil and dizzy, but like Gary says, I'd have thought coil-packs would be simpler and more reliable. The MSD coil driver add-ons are for the original Cossie brain, so I think it would be slightly more involved working it into another management ECU, though I'm sure it's not difficult.
