GAZ adjustable coilover kit
350lbs Springs Rear
500lbs springs front
Front shocks adjust with little wheel on at the bottom, rears from the top using the tool. Adjustable spring platforms do you can set the ride height too.
Been on my car for 5 years, track use only and all was OK when it came off but i've now gone for a much stiffer 3 way set up.
Looking for
