brake discs
tomcat
brake discs
Post by tomcat »
My brake discs are warped and I have been quoted
I suppose it depends on the savings available Scott...... AP will have tolerances for skimming which are probably available on their site but if you remove another 3mm, you'll have lost the bets part of 25% of the original thickness. Too much I suspect.
Godspeed is one of those firms that seem to get such a mixed review online. I have no personal experience mate and only really answered this thread because no one else had! If you are looking to get some custom ones made, there is a guy on a few forums based at Milton Keynes that may be able to help ( http://www.db-power.co.uk/index2.php?page=home ) If warping your discs is a repeated problem, I trust you're looking into a solution?
gary@apt
Post by gary@apt »
yes dont skim any more ive had a set of ap discs crack when lightly skimmed
theres alwasys wilwood do offer some cheap options not something ive used
i have used performance friction with success but id guess they will be dearer than ap
there is a firm called compbrake i have no personal experiance of them but they look good value
Ian200sx
Post by Ian200sx »
compbrakes are a real nice group. well worth giving them call. only heard good things
mk1 escort, supercharged.
tomcat
Post by tomcat »
gary@apt wrote:yes dont skim any more ive had a set of ap discs crack when lightly skimmed
I tried performance friction and they said they are ap special casting -so a no.
The discs have already lots of stress cracks.
Spoke to ian at godspeed and he seemed pretty helpful and would make the discs to the same spec/sizes -only differance being they have straight veins.
tbh the ap discs are pretty old so they have done well I warped them running the pads too low following bealo all day!
compbrake weren't that helpful as they are non std discs and have a larger eye diameter.
question is whether its false economy
Fast Eddy
Post by Fast Eddy »
Another couple of places to try are 3G and HiSpec. Worth a try.
stockcar
Post by stockcar »
let me know the AP part number and or specs and we may well be able to help out..........
we often re-manufacture kits/rotors/ etc. to suit odd-ball installs
alyn
ASPerformance
MOTUL & MILLERS OILS,
online shop!!
tomcat
Post by tomcat »
