See you at knockhill 8)
The yellow Evo completly missed his braking point (at over 130mph) into the hairpin, locked up and slid into me as I was at 45 degrees to him entering the corner.P20SPD wrote:What happened to Kevs car, i saw it on the transporter but didnt hear what happened?
I passed you a couple of times on the way home Kev and by the looks of your car on the trailer it didnt look too bad.SM wrote:The yellow Evo completly missed his braking point (at over 130mph) into the hairpin, locked up and slid into me as I was at 45 degrees to him entering the corner.P20SPD wrote:What happened to Kevs car, i saw it on the transporter but didnt hear what happened?
The driver admitted his fault, but the bill will probably be with me unless he has the ability first and decency second to help out with the time, resources or funds to get me back running ASAP
I was spun around and lightly tapped the tyre wall.
Front end is fine but .....
My car is now shorter on the drivers side, once we opened the door today you can see the ripple ....
On top of that I have Identied the following damge so far .....
Written off every single suspension arm at the rear.
Writen off the rear subframe
Squashed beyond repair the fuel filler tube
Smashed, to a repairable standard the rear bumper
Smashed the rear over-fender from the wide arch kit.
Totalled the OE rear quarter
Bent the rear suspension strut
Smashed the sideskirt - maybe repairable
Smashed the brand new, rear wheel
Damaged the pretty new R888
Cracked windscreen
Broken the splitter, bent the tow hook and grazed the front bumper when I hit the tyre wall
2 weekends before knockhill, 5 before silverstone .... might just get the car sorted for ten of the best at this rate.
Anyone wanna buy a knockhill or Silverstone slot?
