Clio Cup 172, Timing Strut fitted.
Nearly got to sort some eye bolts for the harnessblacky wrote:Good to go then Lee
if i get time and a bit of tape round the earth cable.
If i get time next week, same style or does the part that directs it back to the car need to be any different as mine is fitted to the grill not the number plate as it needs to be 180mm-200mm from the floor?
