Where can the oil pressure sender unit be fitted besides the obvious places. We can't fit it with a sandwich plate to the oil filter due to no room to even fit a sandwich plate :?
Forgot about that....i'm sure there was some reason that we couldn't fit it there before will have to check with Alan but that would be the best place. Cheers Gerry
we have a T piece coming out the side the block with the original oil pressure unit screwed into that and off
the T piece is the flow if oil up to the turbo. going to see if i can take the original one off and fit the after market one.
