Then there's every chance there'll be air in it.pablo wrote:Never thought about the air inside the cooler :roll: . Last year the pipes were on the top of the cooler so the oil basically poured in. After looking at a few others we have inverted it this year so it fills up from the bottom.
Pipes in the top would be better.
If you think about what's happening inside, the oil flows in and forces the air upward. If there's nowhere for the air to get out, it'll just sit at the top and compress when the engine starts. Think central heating radiator. There's a bleed screw at the top to remove the air. Otherwise the top stays cold because there's no water up there.
