Opel Manta Project update 30/05/2009
- ScoobieWRX
Great progress guys,
Glad you are moving forward on this again.
Finally I am pleased to say we have made some progress :-D
Had last week off work and in usual fashion went at it ike a bull in a china shop and got to use some big machines too :-D
Firstly the floor was tackled as this was the major problem. This was solved using what started out as a sarcastic suggestion involving cutting the floor from the skyline to fit the manta.
Before we tackled the floor this is what it was like
Then take one 3dr japanese coupe, some precise measurements, an angle grinder and a JCB :-D
Take a break to move the garden shed
Cut out the floorpan
Brace one very rusty car to prevent folding it in half
Cut out second floor to same precise measurements, Flintstones eat your heart out
Suddenly realise what you have done, team meeting called :-D Decision carry on regardless it's too late now
Using brute force and ignorance (we had plenty of both) put new floor in and check out the perfect tunnel fitment :-D tack into place
End of Part one :-D :-D
Part Two
After lunch lol
Cut out rear passenger wheelarch.
Joggle and weld in replacement panel after treating with jenolite and zinc primer.
Cut out lower passenger rear sill inside and out
Weld in replacement sill, treat with jenolite and zinc primer
Cut out footwell and rebuild door pillar both skins. Treating with Jenolite, seam sealed and coated in zinc primer
Replace inside door pillar with parts from donor car for factory look. Again treated and primed
Replace both wing rails and treat as above.
And that is where it's at now, hoping to get some more done at the weekend but she is now pretty much solid on passenger side :-D :-D Watch this space
Suz
After lunch lol
Suz
