Walbro 255 fuel pumps....Again does anybody run one, looking for general feedback on both of these items.
Gotech Ecu's & Walbro fuel pumps
Gotech ecu's, has anybody got any experience of these or know of anyone that is using one.
- ScoobieWRX
The Walbro is a good pump and way better than OEM. Worth an investment if you are running decent power and need guaranteed fuel delivery come hell or high water. Don't cost the earth either!!
Yes Pablo,
Walbro pumps are used widely on jap cars as an upgrade.
Make sure you go through the right channels and get a genuine one though. There are alot of copies on ebay.
Can only comment on the Walbro. I've had one in tank for ~5 years and it's fine. I now have a Bosch 044 external pump from a swirl pot with the Walbro as lift pump to the pot.
I thought Fords used an external pump?
Fingers crossed the base engine should be in and running next weekend
Having a bit of trouble getting the gaskets are they are on back order but think i have sorted that now. Once the engine is in the car i'll be starting a new thread, don't want to jinks it at the moment
Not a small build though.....basically everything has to be changed :roll:
