Sprint competitors for Class D8 urgently needed
Tyres are listed in the MSA yearbook which comes with the licence, basically it's the rules for competitions.
In there are lists 1A & 1B. List 1A has the tyres that are approved for road going classes, mainly run-of-the-mill stuff. List 1B is for modified classes and includes the usual road legal slicks like 888s and Yoko A048s.
If you run in a road going class you must use the list 1A tyres. Modified classes you can use 1A or 1B and must have a roll cage fitted.
Favoured tyre for 1A is Bridgestone RE070 for dry and, as demonstrated by Kim at a very wet Curborough, Goodyear F1 Asymetric for the wet.
Be good to see you at a sprint from time to time.ESL wrote:If we can get a good turn out for North Weald on the 21st Sept I will see if we can get a mag feature as we can finally promote the series now the MSA has officially recognised it!
