this was taken before i cleaned the grease and muck off with brake cleaner before fitting the lovely exedy organic clutch 8)
found out the clutch had been changed before i brought it but fitted with some micky mouse 5 dorra pile of poo clutch
fitting the gearbox back in, i put the bolts back in the right places with out 5 huge washers to take up the slack on some bolts
the person that fitted the clutch before i brought the car must of been some sort of idiot i swear :stick:
anyways all back together properly and clutch is bedded in lovely no more slipping on full boost wooo :-D
also changed the cat back mongoose over to a cheap 3 inch cat back, its a bit loud but im not fussed as long as it frees up a few ponys
was doing some pre flights checks for a rolling road day at the surrey rollers,cleaned the maf sensor, checked the oil levels, cleaned the earths in the engine bay etc
then i got bored and thought hmmmm theres a big hole left after fitting the front mount and with a bit of spare change in my pocket :-k i dashed out to.... i dont dare say it...... halfords....... :lol:
one pipercross cold air kit and tad da
on a budget it should do something maybe not alot but every little helps i guess, i got a long drive to cornwall beginning of august so it might help a tad
when i get back from holiday in cornwall my next port of call is the handling as i will eventually be wanting to go on the odd track day :-D
