Nope, not much, its fairly simple i had to change a couple and the best tip is use a ball joint splitter to get them out, dont just belt them with a hammer or you risk killing your bearings.
That said i was changing hubs at the time too so i had mine on the bench it may be more tricky to use a splitter with them on the car.
