Sump Extension / Accusump?
323ian
Post by 323ian »
Why do the oil return holes have to be drilled?
GTRJazz
Post by GTRJazz »
Its a design fault of the standard sump some of the oil gets trapped in the back of the sump because the drain back holes are so small. Its in the Tomei sump baffle fitting instructions.
gtir500
Post by gtir500 »
[quote="bimbleuk"]Having seen a Striker go up a bank and hit a tree head on last week on track the front end was surprisingly complete . Yes the chassis rails collapsed and the wheels were pushed back but the radiator was still sealed and no distortion of the driver/passenger area was evident!
That's my old engine the new one is a bit more bling. I would mount it somewhere else but the passenger might object to having it between theirs legs ]
Heres a variation on the same theme
http://www.thinkauto.com/accumulators.htm
slarty bartfast
Post by slarty bartfast »
Im looking to fit one of these to the track car, any recommendations???
Slarty
E46 325 CI + 1999 Pajero 3.2 + E36 M3 track car 3.2 and a Mini cooper S Vert!!!
Buy a group N restrictor so that the head doesn't take on too much oil. I'll find a link for you or I can order two when I get mine :D
slarty bartfast
Is that instead of or as well as??? Whatever it is lol
It's a supplementary thing mate.
Here's some info I found
It's part number 11 12 1 415 562 from BM
slarty bartfast
See if you get some discount for two of them... :grin:
slarty bartfast
Are you doing or has yours got anything done to the fuelling???
I will be using a fuel cell with a swirl pot. Happy to discuss on Wedneday mate :)
