Help! Adjustable Top Mounts for Tein Coilovers
mike-payne
Post by mike-payne »
Does anyone know of an adjustable top mount with caster as well as camber adjustment that would fit the Tein Full Flex coilovers :?:
P20SPD
Post by P20SPD »
Dont the noltec ones fit?
Toy: 550+ Subaru Impreza Wagon
Commute: E46 M3 SMG
Tow Car/Wifes: Nissan Pathfinder
mike-payne
P20SPD wrote:Dont the noltec ones fit?
Zak seems to think they would need machining to fit.... :(
P20SPD
Post by P20SPD »
Exe-tc ones, but they arent cheap!
I assume you just mean for the fronts?
Commute: E46 M3 SMG
mike-payne
P20SPD wrote:Exe-tc ones, but they arent cheap!
Yeah just for the front....
Hi Steve, you believe the The Exe-tc would fit??? thats a start....
P20SPD
Post by P20SPD »
Quite possibly, yes, but there maybe cheaper options out there. What about K Sport?
Commute: E46 M3 SMG
mike-payne
P20SPD wrote:Quite possibly, yes, but there maybe cheaper options out there. What about K Sport?
I guess i need to take the damper off to get some sizes etc. and then start the hunt around...
Alyn does Exe-tc mike ;)
BenTaylor
Post by BenTaylor »
It should only be the sleeve that sits in the spherical bearing and some spacers that you should have to get machined to fit.
BenTaylor wrote:It should only be the sleeve that sits in the spherical bearing and some spacers that you should have to get machined to fit.
Beat me to it :D
The Noltecs have a pair of top hat spacers that reduce the size of the spherical mount. Either drill out for biggr or get a sleeve made if smaller.
