A while back as some of you know my poor old wagon had a heart attack and died due to bottom end failure. It's been sat in my garage now for a couple of months gathering dust and looking very sorry for itself
Well no more
I have just this morning purchased a low mileage Redtop MY04 STi8 engine with all ancilliaries to include:
ECU, Wiring Loom, VF35 Turbo, MY07 Intercooler and new Cambelt. It's almost ready to bolt in!!
To add to this i will be purchasing the obligatory Walbro 255 fuel pump and guaged fuel pressure regulator, Prodrive BCS (care of Duncan), GT Spec Exhaust headers, High Flow catted downpipe and decat center section. It will of course get an oil change (Millers 10W/60), new oil filter (OEM), and set of spark plugs (NGK Platinum or Iridium - yet to decide).
The car will have to be stripped of all it's interior bits including dashboardand plasitcs, door cards etc..., and exterior underboy plastic bits for rewiring purposes, which will probably be the hardest and most laborious bit of all to do as i don't want to plug anything in the wrong way and it would be nice for it all to work first time. With a bit of luck i will be able to limp up to my local Subaru stealership on the WRX ECU to get the the immobilser fob sync'd up to the new ECU. Once that is done i'll get my laptop plugged in and start remapping.
I will have to be careful with the gearbox as that is currently the achillies heal in this whole project so it'll be easy on the full bore standing starts or 3rd gear WOT runs (for logging purposes of course and only on private roads)
I am pretty excited about the whole thing and hope it will live up to my expections which are fairly high but sensible, and safely within the limits of the above set up. I am hoping to generate 330/320 - 350/330 which will be the limit of my gearbox so fingers crossed.
I will keep this thread updated with plenty of photos and mad ramblings as i go along.
At long last!! :internal organs relaxing: :thumb:
