Fingers crossed Mike at Area 52 will turn something up in the morning.
ps - if you read this Mike... thanks for everything so far. Well and truly over and above mate :thumb:
- ScoobieWRX
Duncan, You know Grade A can get it to you pretty damn quick as they deliver by carrier normally, however, you know i will be up to Area 52 myself Sat morning and Grade A aren't much further up the road so if you need it picking up from Area52 or Grade A Sat morning, if that helps same as Gerry
:thumb:
