just click on bmw then the 3rd one down on the drop menu then the second one down on the next menu
then your year and then it is in english
http://www.autolib.diakom.ru/CARS2/index.html
jason
Teehee, helmet on all the way to Cadwell then :-DtommySTI wrote:I just didn't expect it to become so raw. I'm not complaining, just not looking forward to the road miles to get it to the tracks.
Hi AndyAndy916 wrote:Does sound like you might be oversprung, especially at the rear, Tommy.
What is a 'standard coilover kit'? A standard kit from Gaz do you mean?
What tyres will you be running? May be stating the obvious but the reduced weight transfer of those stronger the springs requires stickier tyres to find grip. I expect you might struggle in the wet. With any luck you'll experience both dry and wet at Cadwell which will give you some idea for subsequent trip to the 'ring. Cadwell varies so much between the open and woodland sections that, at this time of year, you often get wet and dry in the same session!
Changing spring rate at rear relative to front will affect under/oversteer balance, of course. Adjustable ARB can give useful fine-tuning in that respect.
You say 'bounces everywhere'. Even on a smooth A-road?
Your old STi is running very nicely on 280/225 lb (front/rear) inverted coilovers btw :-D Will be used in anger for first time at this Sunday's sprint all being well. Might go softer at the rear and use the rear bar adjustment (Whiteline 22mm) to get the balance right. My previous scoob used the same rear bar on max (with the same spring rates front/rear) to be very neutral in the dry but could be a handful in the wet...
Andy
