If I am thinking of the right place which I am 99% sure I am, the twistie bit called "The Snake" is all about handling and transitions from left to right and composure - yours will be fine through there but the trees are very close to the edgeblacky wrote:Sounds good, and slighty challenging!!!
Is it tight or farly open Duncan, eg is it a power circuit or not?
The banked section around the perimeter (ish) is fast as you would expect but they will probably put in chicanes to slow you down.
