Roll Cage + Strip Club.
George @ DCY
Post by George @ DCY »
Ross,
Looking good mate, whats steel have they used ?
Ross
Post by Ross »
Various grades and thickness's of chromoly.
Barries is looking very awesome indeed! The back end is also very original :thumb:
I cant wait to see Gary & Barrie having a tussle round Snett 8)
yagshamash!
Ross
Post by Ross »
We have been making progress again:
All pics taken on my phone :blah:
All suspension arms have been off to the blasters & have now been powdercoated.
The rear bracing has been finished:
Under side of the car is all clean an repainted. :D
Dry build of the new fuel cell out of steel before carbon version is fabricated. It had a nice sump on the bottom & twin -8 feeds.
New boot floor, 95% Carbon sheet :coolsm: (I'm very peased with this little touch Image ) Many thanks to Dynamix for the Carbon Sheet :thumb:
Few more pics of the cage:
:D
yagshamash!
IWANT1
Post by IWANT1 »
Looks the nuts think you should weld the rear door up now......
You going to be ready for the 8th march?
Frigging hell :o
Ross
Post by Ross »
IWANT1 wrote:Looks the nuts think you should weld the rear door up now......
Cheers Lee.
Im hoping its going to be doing some good runs at marham in March. But we'll see...
Gary's is also looking rather special, both cars should be a fair bit quicker this time :twisted:
yagshamash!
slarty bartfast
Post by slarty bartfast »
Proper job... 8)
E46 325 CI + 1999 Pajero 3.2 + E36 M3 track car 3.2 and a Mini cooper S Vert!!!
Ross
Post by Ross »
Cheers Si.
Hows your E36 coming on?
yagshamash!
IWANT1
Post by IWANT1 »
Booking my passenger ride at warp speeeeeeeeeddddddddddd then.
Is there a lad a SHP called Rob as it looks like him in one of the pics??
Cant be many carbon fuel cells about!
Have you done an other engine work since the last event?
Ross
Post by Ross »
I think there is a lad there called Rob. Not sure though.
SHP really are fantastic, they have been 100% straight with me over everything they have done. And have totally exceeded my expectations. I wouldn't hesitate to recommend them to anyone.
Enginewise the car may have a CNC head installed and a Map tweek from Gary @ APT :D The biggest problem last time was the gear box being mashed and not being able to change gear. According to the logs, my car was pulling the same level of G (when in gear :roll: ) as SMD's that did 7.1secs. So all being well it should be in that territory with a good run. I will be running considerably more boost :wink:
We were rushing to get the car ready for the last event, Gary (bless him) really did an awesome job getting then car finished in time. Then there was the added slow down factor of not knowing the car in that level of tune. Believe me when it lights the tyres up in 3rd at 100+mph its quite a sensation :o :D
You will be getting a run for sure Lee me old mucker :D
yagshamash!
