my xmas pressie from the cats arrived ...
IWANT1
Post by IWANT1 »
you spanner skills must be getting better dunk..
Looks the job decent weight saving too..
DIRTYSVT
Post by DIRTYSVT »
On my car the pulley was reverse thread. I removed it by using a breaker bar and while my friend was applying pressure I hit it low with a hammer and it popped loose. Is the diamater smaller? this is where you will see more power since you slow down the rest of the accesories.
-D
No it is the standard size, just lightweight.
Ian (DaOne)
Post by Ian (DaOne) »
nothice anything with it on?
12.29 @ 110.6 santa pod
the scoob is a JDM hoe
It is hard to say Ian but it does 'feel' revvier.
boxy
Post by boxy »
I am amazed that the original crank pulley weighs 3 kgs, that`s a lot of weight. Would of thought being a Subaru the crank pulley would have been fairly light in the first place. Something to put on the list of wanted parts then.
boxy wrote:I am amazed that the original crank pulley weighs 3 kgs, that`s a lot of weight. Would of thought being a Subaru the crank pulley would have been fairly light in the first place. Something to put on the list of wanted parts then.
I was very suprised when I prised it off the crank trying to hold it between two fingers ... it dropped :lol:
boxy
Post by boxy »
Did you manage to prize off the pulley without upsetting the timing Dunc?
boxy wrote:Did you manage to prize off the pulley without upsetting the timing Dunc?
There is an inner timing pulley that is independant of this so no probs there. Just a simple undo a bastard of a bolt and ease it off.
boxy
Post by boxy »
Emmm.... now I`m confused so you have changed the fan belt pulley not the crank pulley? crank pulley involves taking the timing belt off.
