Help needed with video footage
Can anyone help with putting up full length video footage from our trip to the ring. I have 2 video clips of myself and Alan driving the ring in the wet, but i can only upload 5 min segments.
I will be at the drift night this wednesday if anyone is able to help.
Thanks. Paul.
Ben's your man Pablo
Yes mate ... what's the problem with the joining ...
I simply string together seperate video footage using moviemaker .. you import the seperate segments into seperate projects - as each project is uploaded it will create the seperate segments and then you can drop and drag them into a single project.
does this make sense?.
Yes that makes sense but i can only upload 5 mins to photobucket and the clips from the ring are about 14mins long. So how do i get these up on here without splitting them.
Rnash2002
Post by Rnash2002 »
Have you tryed google video for uploading it to,used it on the drag vid that was around 8 mins long and 150mb big.
ValoSunnyGti
Post by ValoSunnyGti »
Hey pablo, if you want any editing done I have adobe premiere so can do wonders with video. As for uploading you can use a place called putfile.com also there are other ones out there. Just google search File Hosting.
Cheers for the advice peeps will see what I can get sorted in the next couple of days.
Ahh so it's not the video editing that is the problem - it's the uploading of the vid to the free sharing sites ? .....
Best thing is to FTP it to an address i.e. your service provider will provide you with webspace ... download a copy of cuteftp and set up the access.
jungle-jim
Post by jungle-jim »
do as russ says.
i have uploaded video's up to 350 mb so far to google video.
anything over 100 mb needs a piece of free software provided by google as russ discovered.
you can load up to 500mb on google.
the go karting video i did was huge too and was uploaded without registration on http://www.streetfire.net they take up to 500 mb too ;)
Cheersguys for all the tips,i will make a note of it all. I have now been able to upload the footage via google video :grin:
