So, the question is, where does that great slug of air go to once the stat opens and the oil flows? Where will this air end up, straight to the sump or, being pushed around the oil galleries to the various bearing surfaces? Basically, I don't know the oil path of the engine.
Is there a right/wrong direction for the pipes, i.e. stat connection to top or bottom of cooler, assuming I can get it in vertically.
Presumably, the capacity of the cooler and pipes will drop the oil level by the same volume once the stat opens
