Having discussed the whys and wherefores I began to wonder whether it may be an inside front wheel lifting. Although 4 wheel drive, the car has an open front diff which will allow the inside wheel to spin and lose drive on the front. Stu's weight was keeping the nearside wheel in contact on the left turns, of which there were many
Anyway, all this conjecture has been confirmed by the pix kindly linked by Rob Callow here:
http://www.phpbbserver.com/clubgtr/view ... um=clubgtr
For those who don't know it's the slightly battered, white Scooby towards the bottom of the page. The pic is taken at the left hander of the chicane (sorry don't know the names of corners) before the pit entrance. If you zoom in to the nearside, front wheel, it's waving in the air. I thought the kerbing felt less vibratory than I remembered :roll: In one respect, I quite like it as it reminds me of those fantastic pix of Jackie Stewart, Graham Hill and Jim Clarke, racing against each other in Mk I Lotus Cortinas, in the days when Formula 1 drivers were less Prima Donna like and would race anything and sometimes causing their tragic demise in the process.
Anyway, I digress. The question I would like to ask of you suspension gurus is Why? and What do I do about it? I know as much about suspension as I do needle point, whatever that is.
I do have, sitting in it's box, a LSD front diff, which I found on ebay. Unfortunately the moronic mechanic who removed it for the seller left it sitting around, uncovered in the workshop and then, I guess, proceded to grind a considerable amount of mild steel in it's direction, covering it in a liberal layer of steel dust that can't just be washed off as there's some magnetic attraction going on. :x
Any suggestions? Is the suspension set too hard? I have KW Variant 3s set pretty much to mid wat, as they came out of the box, Whiteline ARBs set to max on the rear and soft on the front.
TIA
