As some people will have seen, I found an oil leak in the engine bay at the end of my second session at Snetterton on Wednesday. the leak was near the oil filter which on an FD is below the throttle body.
Turns out the oil is coming from the oil seals on the turbos
As soon as I took off the elbow (to look for leaks on the sandwich plate for the oil temp gauge :roll: ) and saw the amount of oil in the pipe I knew to fear the worst...
So after a discussion with Andrew at Jimmy's yesterday and him having had a look today I'm faced with the following main choices (loads of permutations obviously):
1. New/2nd hand turbo pack plus labour to remove engine, replace turbos, refit engine - approx
