hi everyone, 2 things really
1st, on the 52mm link meter gauges, i have a start up mode where the gauges flick about, then go to normal but when i turn of the engine, they just go off.
i read somewhere that there should be a start up and end sequence/mode for them?
and what should the oil pressure be when warm at idle and mornal driving? same for oil temp.
thanks all
ian
impreza classic version 6 sti, defis now fitted, but.....
Ian (DaOne)
12.29 @ 110.6 santa pod
the scoob is a JDM hoe
Ian (DaOne)
There's no 'end sequence' on my Defis, they just turn off.
Have my oil temp alarm at 120 and pressure at 2.0bar. But that's on my car, you may want yours set differently, depends what yours is normally.
Ian (DaOne)
