BMW 520 overheating
BMW 520 overheating
I have no idea where to go next! :oops: My wife's 520 has been overheating speratically. I have changed a range of parts from the radiator hoses to the heater core and the thermostat, still no progress. I have used sealant for all of the seals and flushed and serviced the radiator countless times. I feel like I am at a deadend, does anyone have any experiance with 520's? I am lost as of now. Any suggestions are welcome!!!
When you fill it up do you make sure there is no air in the system - my golf was overheating and part of the problem is the way you are supposed to add coolant - i.e. put some in - leave the cap off - get it to temp and top up as you go ....
Plus, is the fan cutting in when it should?.
Yes i agree with Ben, try for air locks.
Just a couple of other ideas. Is the water pump doing its job and is the system holding pressure via the rad cap and expansion bottle cap as i have found this to be a common problem that people do not realise.
Good Luck
Good Luck
Sounds like the fan is a viscous one - i.e. on my car it's driven straight from the engine and when temp is up the coupling adjusts and allows the fan to spin ... so you wouldn't expect it to spin immediately ..
if however it's an electrical one then it's down to the temp sensor ...
Anyway bryan can't you just pretend it's an F15 and get your crew to fix it
John, I will start with the cap first then, sounds like a cheap first step, then on to the temp sensor.....ahhhhhhhh electricals!
Thanks guys, I'll keep you posted on the progress.
This is the devil itself, not bad to look at, but thats about it!
http://s71.photobucket.com/albums/i134/ ... s002-1.jpg
