Bladerider wrote:I was talking to Stuart about this,
For those that may be interested on the day........
The drift course will basically be as follows......
A fast, slightly downhill approach at around 75mph into a 90degree left hander which you would initiate on the handbrake early and hold into the first corner, not taking an apex on the inside in order to clip the right hand side of the track on the straight to the next corner which you should acheive in one smooth motion, accelerating flat out before the entry into the second 90degree left hander you will clip the inner apex of this corner and then edge out again maintaining a smooth drift again without any sawing or yawing movement, once clipped you should pretty swiftly be looking for the next gear (3rd or 4th depending on car) as you transition to the left side of the track now going uphill for the right hander that is also a crest and not quite 90 degrees which opens to the long left leading to the start finish straight by which time you should have got back up to 75-90mph and be foot on the floorboards in ready to grab 4th if not already in it !!!!
Judges would expect a half metre distance or less to the curbing on the outer edge between the first two corners for zone about 10 metres long, then another half metre clipping point on the inner apex of turn 2. I expect same again for turn 3 on the inner apex and if they want to make it more difficult and do what they do at Silverstone then there would be a zone (basically a section of track that you have to hold to) on the outer apex of 4 just before the bridge. Last year most of the judging was on the entry speed and angle, the section between turn 1 and 2, and the clipping point on 2, the rest of the course was just kind of a disqualifier if you didnt make it. Now they are judging the rest of the course so it should be that much harder again. Its an extremely technical piece of track with very little room for error.
Hope this helps,
j.
Ahh cool - now that I've read that - fully understood it - and I can now drift
- now a few more hours on GT4 .. I'm the racing god of akina.
