mike-payne wrote:Top man Steve......
Nice cars, although i always found them a little light on the front.
They also have issues with the mechanical diffs, but i'm sure there are uprated ones available.
Look forward to toying with this on the track :twisted:
right.... some coupes have the type "A" torsen diff.
later cars had a better type "B" diff.
the diffs are very strong. its the bearings and seals that suffer.
speak to martin on here who has a scooby. he rebuiolt my box and does them for a good price.
this is quite easy.Spec'C'57 wrote:Best i look into a rather LARGE turbo then... :twisted: Lorry turbo anyone???
you need either a T28 from a nissan 200SX ( S14 ) or a pulsar.
the pulsar ones will produce more power in the end because of the larger exhaust outlet.
the S14's is smaller and reduces the lag but less kick in the back and ultimate top end.
the housing needs to be rotated to fit and the actuator arm bent. this is not difficuilt.
i have a GT28R on mine and it has the benefits of both T28's.
budget about
