just got a 3 point strut brace for my evo 4 do anyone now how easy this is to fit
if i undo the 3 bolts either side do i have to hold the springs up or anything like that
any help would be great thanks
I dont know evo specific, I assume you are talking top brace, but if the strut/spring is on the underside of the turret (which it will be) then with the weight of the car pushing down there is no problem undoing the nuts to fit your brace ;-)
follow the evo torque settings when doing the bolts back up.
The hardest part will be getting the interior panels right, if you are fitting the rear, if they need to be modified.
Easy job, get the spanners out :-D
'05 Subaru WRX 300
R.I.P
'89 ST185 GT4
ONLY 370bhp & 405ft/lb @ fly
12.7s 1/4 @ 109mph in the wet
R.I.P.
