Dyno and speedo vid/pic
jamiep
Post by jamiep »
Had a problem with a rear diveshaft so had to abort mapping, all fixed now so back up there next week to finish of mapping, Made 500bhp and 619NM at only 1.1bar, more to come 8)
Dyno vids
http://media.putfile.com/JamieP-dyno
http://www.youtube.com/watch?v=eWJVwkn3 ... er&search=
Speedo vid
http://media.putfile.com/Jamiep-speedo-vid
rayman gtir
Post by rayman gtir »
wot is that lick of flame from in the engine bay, wouldnt of thought that be normal, is it or safe. love the squeel of the turbo.
also i take it that speedo vid is from you private runway :?
Bloody impressive figures Jamie, do you have the dyno sheet?
I take it that was your manifold blowing? Looked spectacular enough :)
jamiep
Post by jamiep »
Thats just the external wastegate, it points directly at the floor but with the bonnet open the flmes take the easiest route, flames have burned a big patch of the rollers :-D we only did one run and i never got a power graph as i was worrid about the wheel and forgot, wheel all sorted now and ill be back up there next week to finish of the rd fuel map...
rayman gtir
i thought that after i posted it was probably wastegate
rolty
Post by rolty »
Sounds lovely, love the lick of flame in a scary sort of way :lol:
I take it the spped run was done on a private road though?
jamiep
Post by jamiep »
Yup, speedo run done on a closed private buisness estate :wink:
That is quite simply a stunning supra mate. Love it.
boxy
Post by boxy »
Dam, can`t see the vids as for some reason quick time doesn`t work properly.
rolty
Post by rolty »
jamiep wrote:Yup, speedo run done on a closed private buisness estate :wink:
:-D
