jungle-jim wrote:well in that case!! yes, your battery is fudged mate!!
i didn't realise you used the car so little!!
get the alternator checked for sure ben.
a flat battery will easily overwork an alternator.
you might want to invest in a trickle charge system too.
Of course, the battery may only be failing under load - if you buy a battery from Halfrauds, ask them to check the existing battery first with a load tester across the two terminals.
Lack of use of the car can ruin a battery in less than 12 months, as did my R34 GTR (same thing through lack of use). Hence buy a battery from Halfrauds. If it fails within the 3 yrs which seems likely, - get a new one!
Nik
