Harness mounting points on Subaru Impreza (Newage)
blacky
Post by blacky »
dynamix wrote:nope - you dont even need harnesses.
For feel tho its really essential i think.....
Okay, amy just get the 2" ones like yours Dunc, will do me for a while :D
Rules and regulations are as per GT Battle 2005 and the driver must wear a crash helmet, long sleeved top, long trousers, hard footwear and have a fire extinguisher within the vehicle. Racing attire is recommended but not compulsory. Vehicles must adhere to safety regulations as per a trackday so ensure your vehicle meets these requirements.
I'm with you on that Logan. Normal seatbelts dont hold you the same.
"MADDOG"
Post by "MADDOG" »
guys, i have this bit of kit, works very well and you can still use your standard seat belts when you are not using your harness's. It does however need a very slight modification to make it fit New Age cars.
http://www.sparcousa.com/harness_bars.asp
regards "MADDOG" :-D
wow - that look good Andy. Will have to take a peek at yours at the next meet :thumb:
RobCallow
Post by RobCallow »
That does look good also could use it to mount a camera on.
Rob
blacky
Post by blacky »
&quot wrote:guys, i have this bit of kit, works very well and you can still use your standard seat belts when you are not using your harness's. It does however need a very slight modification to make it fit New Age cars.
Good idea, only issue is that you would not wanna have rear passengers in teh car with that bar there, if you were in an accident that them dead basically :o :o :o
Think I will stick with the standard mounting points with teh quick release clasp so I can easily remove them for using the car normally.
"MADDOG"
Post by "MADDOG" »
Understand your comment entirely blacky , but since i have owned this car i have only had one person in the back and that was my wife :kiss:
