I ordered a set of 3" harnesses from the bigpower shop and I have recieved an email from them regarding the mounting points on the Impreza.
He belives that the mounting points are not directly behind the seat so the harness can be mounted in a straight line.
Has anyone fitted a harness to an Impreza if so did you have to modify the mounting point?
Harness mounting points on Subaru Impreza (Newage)
I saw this type of harness I really wanted to go for a four point set up. :?
Think I will have to have a look behind the seat to see what I can do.
May get my dad to weld in some mounting points for me I have seen them somewhere where the eyelet screws into a plate could get two of these welded in. :?:
Rob
They dont even have to be welded in.RobCallow wrote:I saw this type of harness I really wanted to go for a four point set up. :?
Drill one big hole for the eyelet, drill a small hole for the support screw and you're done. I spoke to the guy on the TRS stand at the Autosport show who recons it is just as good as welding them in.
