Following on from detailed discussions on 22b.com there is a vast amount of people that run Methanol as an Octane booster by adding around 10% volume as methanol.
Has anyone here tried this and been able to log the differences in charge temps due to the cooling action of methanol?
I appreciate that some consider it corrosive but that aside (and ignoring Water Injection systems in this instance) how have you found that it affects the amount of advance you have been able to run?
It looks an ideal solution to octane boosting to me, as well as benefits from charge cooling.
Methanol
Speak to Scott about methanol, I know he has used it in the water injection system and produced a good write up comparing what mix to use.
Not sure if he has used instead of petrol though. It cant be that cheap !!!
He has given me some to try in my water injection......havent been brave enough to try yet. :oops:
I tried it at 10% mix with Vpower when@ the Ring.........seemed ok. No technical feedback to offer I afraid mate
If you add methanol to your tank you will raise the RON of the fuel
ie
90 % 99 RON
10 % Methanol 123 RON
89.1 + 12.3 = 101.4 RON
The new stoich for the blended fuel will be
90 % 14.7 petrol
10 % 6.6:1 methanol
13.23:1 + 0.66:1 = 13.89:1
Methanol has less energy per cc than petrol. If you replaced you petrol with methnol you would need to increse the fuel system by 2.2 times.
ie i run 4x 850cc = 3400cc i would need 7480cc to support it
methanol has 15 mjL
Petrol 30mjL
So if you add methanol for every 10% you add you will be leaning out your fuel mixture by approx 9.5 %
The fuel system will not like methanol. It is very corrosive and also takes on water. It attacks zinc and alu. Methanol is conductive and will slowly kill you fuel pump o rings fuel line and fuel rail.
Methanol need a great deal more advance in the timing as well.
Methanol is a heavy degreser as well so will clean oil out of the engine and will also contaminate it.
Scott
ie
90 % 99 RON
90 % 14.7 petrol
10 % 6.6:1 methanol
methanol has 15 mjL
Petrol 30mjL
Scott
