cleaning
Edit: You caould alwyas go to plan Bfrayz wrote:Autogylm machine cleaner should do the trick, if that wont shift it, try some tetrosyl engine degreaser.
The Autogylm is non toxic and okay on the environment, the tetrosyl however is a little harsher.
Try the autogylm first though mate.. both should be available from Halfrauds
Plan B is to paint it wrinkle black like Gary from APT has.. His is bloody gorgeous
