My Sierra RS500
Lloyd@JRD
Spec as follows
200 Motorsport Block
Cosworth pistons 7:2:1 compression
WRC 4 layer head gasket
Larger ported head
NMS inlet cam made from blank
NMS chip
Solid lifters
GT35 turbo with external wastegate
8 light blue injectors
Coil pack ignition
Pectel Super 8 ECU
Twin dump valves
Radtec radiator
Water injection mapped to come in at 1.5bar
Oil cooler
Turbo pre-rad
Vernier pulleys
Water cooled power steering
9" Touring Car diff with 3.6 ratio and solid mounts
Group A rear beam, fully adjustable - camber & toe
Bilstein coilovers
Adjustable front track control arms
Quaife gearbox
Hydraulic clutch
AP 6 pot front brakes with 330mm floating discs
AP 4 pot rear brakes with 330mm discs
Pro Alloy fuel tank and swirl pot
2 x Group A fuel pumps
17" x 8" Comp Mo wheels
Stack gauge
Defi oil pressure and EGT gauges
Apexi boost gauge
SECs monitor
Cobra Evolution seats
TRS 6 point harnesses
Safety Devices roll cage
Jobs to be done:
New custom built exhaust, to get it below 106db
Spec as follows
Larger ported head
NMS chip
Solid lifters
Coil pack ignition
Pectel Super 8 ECU
Twin dump valves
Radtec radiator
Oil cooler
Turbo pre-rad
Vernier pulleys
Bilstein coilovers
Quaife gearbox
Hydraulic clutch
Stack gauge
Apexi boost gauge
SECs monitor
Jobs to be done:
- Miniwilliams
What A Fabulous machine!
PM or E-mail me some details
